I live in a Condo Complex and in the attic they have some Old VHF_UHF antenna and they are connected to the units via a Wall- Jack.
I did unscrew the cover to the TV jack and then I pull the cable and connected to my Portable Scanner ( I cut around the cable ( jacket and breaded shield) until I had a straight center conductor so I could put it in the Bnc Connector of the scanner and I was able to pick up stuff like local Pd’s and MSP (I do not believe that anyone in the condo complex use the old vhf-uhf TV jack (they all have Comcast of FiOS) and I was happy as it believe that the Attic antenna will do a better job then the telescopic cheap antenna that come with the Pro-197.
Unfortunately, I could not test on my pro 197, as the cable coming out of the wall is very short.
My Pro-197 is about 17 feet away from the Jack and not sure if there, any gizmo I can use to connect that jack and then connect a RG 8 RS cable to the scanner.
Any help or advice is appreciated
