Hi,
I recently purchased a Pro-106 Digital Trunking scanner and have been happy with it so far. However, the stock antenna seems to be the only negative I can find. I went out and purchased a RS 800MHz antenna and it seems to be working a little better, but in my room I need to put the scanner on a tall desk to pick up trunking transmissions (which I also did with the stock antenna). Was it a bad choice to purchase the new antenna or will I benefit from it. Also, my local trunking system is a 400MHz system.
Thanks!
Thanks!
