conve36
My situation:
I have a PDI "splitter" that looks just like the one in the picture.
It says "Mega Splitter" "2-Way 5-1000Mhz"
I have one antenna line coming in and connected to the "input".
It has 2 other connectors that each say 3.5dB and have 2 scanners hooked up to there. One scanner monitors an 800mHz trunked system and the other monitors mostly UHF conventional channels. I dont seem to have much of any signal loss in the 800Mhz freqs using this splitter or a "T" connector and any antenna I use... (trying to get the most out of the UHF area...)
My question: (regardless of what frequency bands I listen to)
Is it better to use this "splitter" than to use a PL-259 or BNC "T" connector?
Can this "splitter" be used the opposite way? As in hooking up 2 antenna's on the bottom connectors and one scanner to the "input"?
Should I hook up a ground to this splitter? (Will it make a difference?) I have it grounded at the antenna..
And yes I know this is NOT the best way of using 2 scanners with on antenna or vice versa, but I am working with what I have at the moment...
Thanks everyone!
Thanks everyone!
