TheListeningPost
- Joined
- Jul 26, 2008
- Messages
- 0
I've been using a Diamond RH77CA with my PSR-300 almost since the day I bought it (well over a year ago). I recently bought the RS 800Mhz antenna in order to improve reception on the 800 Mhz trunk system in my area. To my amazement, I seem to be finding better performance across most of the bands and not just the 800Mhz band (but especially the 800 Mhz band).
It seems like i can hear 2 meter hams much more clearly with this antenna than even the RH77CA! I know that it doesn't make a whole lot of sense, but it's the truth.
I think I know what the problem was though. I think the RH77CA is too much antenna for the PSR to handle. I think it was getting over loaded. Because with the RH77CA I was getting either FM broadcast radio or TV audio bleeding over on around 146.5-7 (2 meters).
Am I better off just keeping the 800Mhz antenna on the radio as my "mainstay" antenna, or should I continue to toggle them?
