It's possible, if it's VHF. I can pick up a police station over 60 miles away that is VHF. But if it's UHF, 50 miles is quite a long distance, but still possible if the station outputs enough power and you have a good antenna setup. But it would still be weak at best. For best results, you could use a directional antenna pointed at where the signal is coming from.
