Hi all,
Apologies for this really newbie(daft) question!
I've had an Icom PCR-2500 for a few months and, living in a flat, just used the telescopic aerial that came with it, plus a UHF/VHF aerial with an HF wire, that I hung up inside my flat. Needless to say reception wasn't that great.
Now I've moved into a house and was keen to at least get the aerial into the loft while I look into the possibility of mounting a proper aerial on the roof later.
I'm absolutely terrible at DIY and so I was trying to figure out if I could drill a hole through the celing to feed the cable from the aerial in the loft to the room where the Icom will be. Then I noticed there is a TV aerial point in the room already. Up in the loft, the TV aerial cables come in through the roof, and there is an adapter with 3 separate TV aerial points, and each of these cables feeds down to 3 rooms where there is a TV aerial point.
My question is, to save me drilling, and possibily falling through the ceiling while crawling along the edge of the loft, could I just plug my UHF/VHF aerial into the TV aerial cable that comes up from the TV point to the loft? I can unplug it from the TV aerial adapter in the loft and plug it into my aerial instead, then I would simply plug the Icom into the TV aerial point in the bedroom and - bingo - the connection is made!
However, it seems to me that life is never that simple.. is that cable meant for TV signals and will it be rubbish for transporting the signal from my VHF/UHF aerial into the Icom? I did try it, and it sounded ok.. I was picking stuff up but, living in a new area, I'm not sure if I should be getting stronger signals.
One further question.. the UHF/VHF aerial has a connector for grounding it. I'm not sure what I should attach this to in a loft - any suggestions?
I'd really appreciate any help on this. I know it's a daft question, but it would be so handy to just use this existing cabling.
Thanks!
Thanks!
