I Have an old HF unit that I want to set up for receiving Shortwave. I have a kit from Radio Shack that I got at surplus. It is the 278-758. It has 70ft of antenna wire and 50ft of lead in wire.
My question is would there be any advantage to swapping out the insulated lead in wire for coax? If so, what would you use?
The reciever goes from 1.6 to 23 mhz. Obviously there will be no one ideal length to use if I have no antenna tuner, but I could not use the tuner that it normally uses becaues without the proper license to transmit, I could not activate the tuner. I suppose you could not activate the tuner either if it is only hooked up to that type of antenna. The antenna wire is 20ga and the lead in wire is about 22 or 24ga. I should be able to get a manual tuner for it though, correct?, and just do it by "feel"?
