Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas - For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
Old 12-28-2008, 1:35 PM
Default My new Centerfire Discone
Got a Centerfire Discone antenna for Xmas, so I just got done mounting it up on my roof. I used a piece of 3/4" Galvanized pipe 4' long srewed into a flange that is Lag bolted to the roof.
I still need to get my coax and run it up to it, debating on where I want it to enter the house. I'm planning to use RG-6 coax 50 or 75' long (depending on how I run it) with a PL-259 to the antenna and a BNC to my Pro-106.
Here's a couple of pictures of the new Antenna
~Jason
Scanners
- Uniden Sportcat SC150 with Stock Ducky
- Radio Shack Pro-106 with Stock Ducky (for now)
Old 12-28-2008, 1:57 PM
Cool nice
nice install
Fire Fighter I/II, PRO-95, PRO-107, PRO-96, Uniden BC895XLT,
Old 12-28-2008, 2:39 PM
trooperdude's Avatar
Since Discones are unity gain to begin with, you'll lose some signal if you don't use at least RG6U Quad Shield with an actual COPPER center conductor, and not a copper-plated steel center conductor.
Why not LMR400 at least ?
http://www.firesafecouncil.org/
Be Fire Safe California !
Old 12-28-2008, 3:38 PM
Well I was going with RG-6 because it is readily available in my area and won't break the bank, I should be able to get my hands on Quad shield pretty easily. I didn't really want to order anything because I'd like to start using my new antenna soon, I'm impatient...haha
~Jason
Scanners
Old 12-28-2008, 4:29 PM
wow,what is your range with that on the pro 106?
Radio Shack Pro 106 Owner
Radio Shack Pro 2054 Owner
32 Inch Westing house HDTV
PSN - forrest24
XBL - WAHOOS 4 LIFE
Old 12-28-2008, 4:31 PM
I don't know yet, waiting to get some coax and ends so I can run it and give it a maiden voyage
~Jason
Scanners
Old 12-28-2008, 5:40 PM
tell me how it does cause i want to do the same thing but like 33' up in the air
Scanners: BCT-15, Pro-106, Whistler 1040
Radios: Icom 3161, Connect Systems CS580
John 15:13 - Greater love hath no man than this, that a man lay down his life for his friends.
Old 12-28-2008, 6:27 PM
smason's Avatar
Looks a little short on elements compared to most discones, interesting.
Do let us know how it performs
Lots of radios, not enough antennas...
Old 12-28-2008, 7:05 PM
pddispatcher's Avatar
Walmart has 100 ft run for $34-$36 Phillips Brand RG-6 Quad Shield
Radio Shack Pro-2096
Kenwood TK-272G
Kenwood TK-5720 (P25 Mobile)
Kenwood TK-5220 (P25 Portable)
Old 12-28-2008, 8:22 PM
Walmart huh? Hmmm I might have to go check that out! 100ft is more than I need but might be worth crimping a new end on anyway. I also have a local Electronics store going out of business, 50% off everything. I'll have to see what he has left.
Also, yes I noticed it has few ground radial elements than other discones, so I hope it's still a decent antenna. I've read some ham reviews of it and they said it was decent, so we'll see
~Jason
Scanners
Old 12-28-2008, 11:16 PM
They sell them in 25/50/100 ft sections.
Kenwood TK-272G
Old 12-29-2008, 3:55 AM
nice install!
Old 12-29-2008, 4:36 AM
MOTOROLANUT's Avatar
Thumbs up
Ditto on the install, Good Job!
