The subject of grounding antennas has been covered by I don't know how many threads over the course
of time on here and a number of other sites. What ever you hear or read on these sites is in most
cases based on the personal feelings of some of the miss guided people there. There are others that
will point you to do your own homework and come to your own conclusions.
With that said, you should spend some time looking through section 250 of the National Electrical
Code (NEC). Here you will find a number of references to grounding antenna systems, spacing
ground rods, bonding different ground systems together and as in your case, grounding of the
electrical system of a hot tub.
Another issue that most don't even think about is that the house insurance carriers even have
guide lines as to how your external antenna system should be grounded. In some cases, these
insurance companies have with held insurance claims from lightning damage due to the antenna
not being grounded or by the grounding not meeting certain specifications.
So it would be to your best interest to do some homework on your own and not believe all that
you may read on sites like this one. I have been in the electronics and radio field for well over
40 years now. About 15 years of that time I was building cellular communication tower sites.
Not that you need to go to the extent that the cellular companies do to protect their sites, but
they do stay working after taking a direct lightning strike.
It is not any one grounding item that does the surge protection, but all the different things that are
done to protect a facility. The electrical service, the telephone surge protection, the tower
ground, the building ground, the coax cable grounds, the grounding of the equipment racks,
the grounding of the chain link fence and so on all contribute to providing a total solution.
Do as you please, but also do your homework.
Jim
