Hay Don, how do you get the antenna from the roll bar through the fabric top? Do you only use it when your top is off?
My jeep is a 2007. The fenders are 100% plastic. So no magnates there. I drive it on-road so I worry that a cop will pull me over if it is on the hood, obstructing my view.
Would running a ground wire to the antenna base work? Would running the ground wire bundled with the antenna cable degrade the signal?
How close to the ground plan does the antenna need to be? The roll bar, windshield frame, door window frame and support hoops are the only steel within + - two feet of the top.
What could suffice for a ground plane? The good old cookie sheet under the top?
Thanks again for the help, DJ
The roll bar is under the top, so no biggie. The 2 antenna I have mounted on the roll bar itself are satellite antenna, one for GPS the other for XM Radio. They're small, about 2" in diameter and have a magnetic base. So I just unwrapped the padding, plopped the antenna on the roll bar (one on each side) and ran the feedline up, under the padding into the front by the windshield and then down to the radios.
As to the scanner antenna, it sits inside also, on the "shelf" between the front and rear mount for the rollbar (over the rear wheel). It's a much larger antenna (a Larson 150/405/800) but works very well from that location.
Yes...ideal location would be center of the hood...but that's kind of ugly (to me) and I don't think it'd be that much better than where I have it currently.
Fabric top or hard top (plastic)...doesn't matter...the fabric or plastic won't attenuate the signal enough to make any difference. Obviously, if you were going to put a "normal" antenna on the roll bar, or on a sheet of metal welded to the rollbar....getting it to stick up through the fabric would be a trick. I suppose if I absolutely had to have something like that, I'd go with a car-top carrier (they bold to the fenders and sit over the roof) and put the antenna on it. Be kind of expensive, but it'd work fine.
Yes, a physical ground helps, but remember...a "ground plane" is merely a reference point for the antenna itself. Typically, it's the other half of a dipole. So the larger ground there is, and the better bonding to the actual metal frame of the vehicle...the better the antenna works. Again...it's all relative....we're not taliking huge differences, but they would be noticable between a well grounded antenna setup and one without a ground.
Another option (I use in my RV) is a marine antenna. It's designed not to need a ground plane. But I don't know of too many marine antenna that are useful for more than 150MHz. In my case, the Marine antenna is for XM radio...so it's small, works very well.
