J-pole "caculator".....
Does any one have a J-pole Calculator that lets you change the tube size from 1\2'' to what ever you want? I have found an abundant calculators but all of them have fixed tube size. I would like to have one that lets me change size so I can make large surface area ones and micro poles.
Michael,
If you're going to mount this antenna outside, may I suggest the "Slim Jim" from
www.hamuniverse.com. It's not a commercial antenna site, but rather one for antenna experimenters. The "Slim Jim" is sort of like a beefed-up, J-Pole. The antenna is 3/4 wavelengths high on the long side and slightly less..1/2 wave on top and 1/4 wave on bottom with a "gap" in-between. You'll see the diagram and even pictures. No, the guy in the photo is NOT me, that's Richard, LOL!
I've built the antenna, using RG-8U for feedline and it works! It has a lower "take-off" angle to the horizon, so you "hear" farther and talk farther out in all directions. No, it won't beat a good, multi-element quad, but you should hear more stations. When I had mine up at 40 feet, I could work the 147.33 mhz repeater in Alexandria, LA. (125 miles away!) with 50 watts from my Icom 706 MkII-G. At 30 feet (when storms blew through) I had no trouble accessing the 146.88 repeater in Nachitoches, LA, about 70 miles away with the Icom.
I have not built a 440-470 mhz version, yet. But I will be moving this year at some point and will set one up at the new place.
The good thing about this "hobby" is it allows you to 'experiment' with different forms of antennas and different materials: wire, pipe, omni-directional, quad's, yagi's, longwire, top-loaded, base-loaded, etc.
Here, I'm terribly restricted as to lot size and living near the State Hospital's trauma center's helipad. :-( The new place, outside of town's lot, is still narrow, but very long and has a workshop to build antennas out of the heat, rain, and cold. ;-) I'll even have room for towers (YEA!!)
Respectfully submitted,
73,
Don/KA5LQJ
