Has anyone had any experience with this antenna? I am considering picking one up, as the majority of my monitoring is in the 500 - 860 MHZ range.
"Designed to receive the major UHF Bands between 300 and 900 MHz. Including the digital trunked systems and the new 700 Mhz band. This antenna will also receive local VHF 150-220 MHz and 1200 MHz traffic.
Type F connector allows the use of low loss 75 ohm coax cable. RG6 or RG11 is recommended and is available at home improvement stores. This antenna can be used indoors or outdoors."
http://www.centerfireantenna.com/newitems.html
