AlmostHandy
I'll try not to spew, like I normally do.
1. I plan to use LMR400 as the feedline from a Wifi dish. Can I attach an RP-SMA connector directly to the LMR, or should I use a pigtail.
2. If I should use a pigtail instead of connecting the RP-SMA connector directly to the LMR400, should I use N , or TNC. I've heard UHF is very bad above 300MHz. Is that accurate, or can UHF connectors be used with a wifi connection?
3. How far above the ground should a ground plane antenna be, minimum?
Thank you.
Thank you.
