AlmostHandy
Is there a limit to the number of director elements a Yagi antenna has?
thinking about your next build?
lol yup.
I wonder if I can make a yagi for Wifi. Could I use #12 Solid coper wire with an 8 foot long piece of copper pipe? The reflector is only 69mm long, so I have some ideas about suspending the whole thing inside of a piece of 6 inch drainage pipe. Would that work, or would PVC attenuate the signal.
The calc I'm using says that you can bond the elements directly to the boom, and refers to them as parasitic. I haven't been able to find any information about this type of element/boom connection on any of the homebrew pages. None of the amateurs even mention bonding the directors to the boom. Is there some reason that insulating is better? Better gain? Better aperture? Better SWR?
Why don't you go the other way?
Yes, I know.
Doing things ion the logical sequence is out of character for this forum.
What is it you want to do?
What gain is required?
THEN
Decide what antenna provides that gain best.
Yes, I know.
. . . But you speak the truth!
lol yup.
You can use wire and water pipe, but it's going to be massively overbuilt boom and flimsy elements if you do.
Yes, you can bond reflectors and directors to the boom (or not). You insulate the driven element from the boom though if you use a metallic boom.
