I use a CB antenna for all bands, not optimal by any means but it works fine for me,
get yourself the adapter you need from Radio Shack (yes for the purists,this also cuts in to reception). If you find it works for you, great, if not, explore Plan B, a scanner antenna designed for the bands you monitor. Good Luck.
