Just got my new antenna OMNI X from DPD Productions.
DPD Productions - Scanner Antennas
The antenna came in a well packaged box and was in very good shape when I opened it.
I checked out all the parts and read the instructions (really!) They were very clear and
easy to follow. There is not much to assemble and it is important to do it correctly.
All elements went in ok except one. It was a tad big or the holes were a tad small.
This made it a challenge to align the holes so that the screw would tread properly.
But after a few tries and a small flashlight I was able to set it in.
I had a 15ft cable so I HAD to connect it and hear what it could do inside! (first pic)
Well at first listen it makes a big difference! I can't wait to mount it on my pole outside.(second pic)
My side mounted roof pole is about 30ft off the ground and clears my roof by 8 feet. So this
should be a good place for it.
I have attached two pictures of my project and will add another post after I get my new bury flex
cable and mount the Omni X outside!!
Z
Z
