Ok here we go I need to 2 antennas to 3 scanners can anyone give me a link where I can buy one
"Put as much thought into your question, as you hope people will put into the answer"
This is a fabulously concise way to state that concept. I think that should be officially added to the "Forum Rules and Etiquette" thread.
All I would like to know is if anyone can suggest how to connect 2 antennas to 3 scanners if it is at all possible. If this is possible, please provide a link where to buy what would be needed.
The "connect 2 ants to 1 radio" sticky at the top of this board could provide a lot relevant info here. The short answer is: bad idea.
I have one UHF & one 800mhz antenna, I would like to connect these 2 antennas to 3 scanners.
Oh jeez. I just checked a retailer for those splitters, and they're $140 bucks. I guess three of them is a really expensive solution.
Don't believe the hype. Combining signals from 2 antennas with random phasing is not going to work. The combining of two specific band antennas with a diplexer is a different story.
How can you declare that it "is not going to work: when he has not told us what "working" or "not working" is to him?
While I usually don't recommend combining antenna, most of the times people have asked it has been to get some specific issue resolved (e.g. pick up a site that one of the antennas will not get).
In this case, you will get some random signal cancellation, but as long as you are not looking for peak gain from either antenna, you random combination will may give you acceptable results.
Predicting EXACLY what the results will be is difficult if not impossible without a very detailed study of the set up.
Yes, using a frequency specific combiner (diplexer) will yield better results. About 3 dB less signal loss, and a much lower probability of signal cancellation on any particular frequency in any particular direction.
P.S. Since the antennas were described as frequency band specific, the diplexer is not absolutely necessary.
I declared that it would not work because I made an assumption that he is not looking for improvement on a specific frequency. IF he is then he might be able to do what he wants. This would require a lot of the information you asked for earlier.
The diplexer might not be necessary but it would sure be beneficial. I say that because a low band vhf antenna will receive some 800 MHz signal and if it is the wrong distance from the real 800 antenna its sgnal will cancel some of the signal from the 800 antenna. The diplexer would block some of the 800 signal coming from the vhf antenna thus reducing the cancellation of the out of phase signals.
I can almost agree with you if you said "not work well", but saying that it will "not work" is wrong.
What is the probability of a signal on either band coming into the other antenna at EXACTLY the same amplitude and 180 deg out of phase.
He already has a slight advantage as each antenna will be several dB down on the other band.
Yes, I diplexer or other tuned combiner is the right way.
If we knew exactly what type of antennas we might even make other recommendations.
I agree with you. "Not work" was not technically correct.
Signals do not have to be 180 deg out of phase to combine the wrong way. If they are out by 90 deg then 3db of signal would be lost from the main signal??? Not sure about that number as I'm not real good at math.
