I'm using it for a base.. I'm on the 2nd floor indoors, My bedroom has vaulted ceilings so I put it up towards the center of my room as high as I could go. I pull in a few freq's I couldn't before on the 400 range and the 800 range has also improved.. When I try to listen to air band I can here but its very low, and staticy. when I tune to CB, I get barley anything, I hear what sounds like very soft voices but static when they are talking.. I just need an Antenna so I can pull in air and cb.. but If I had to make a choice between the two, I want air band the most.. Thanks for your recommendations!!!
