dpmizell
To anyone installing one of these antennas be carefull while tightening the 3 lower elements and use the jam nuts provided. I did not use the jam nuts and grounded the whole antenna by running the elements in to far. I noticed I was recieving better with the rubber antenna than with the new antenna. Got out the meter and ohm'd the cable and antenna. Found the Antenna grounded. Other than that ive got it about 25' off the ground and sitting back copying the mail.
