mlconnell
Hey guy's I was going to buy the BCD996T again from Bearcat warehouse and they have this antenna..
Is this antenna below good and is it worth $50.00 ?
Spider Scanner Base Station Antenna
The Spider Base Antenna is a complete base station antenna kit made specifically for use in the home. The antenna is designed to receieve scanner signals between 25MHz and 1300 MHz. The antenna includes a complete mounting kit for mast-mounting and 50' of RG58 coax with both Motorola plug and BNC connector. This base antenna assembles and mounts in a matter of minutes as it can be mounted to a mast, a vertical or horizontal rail, or to the side of any building or structure.
* 25-1300 Mhz*Ideal for ALL Band Scanners Low Band, High Band, and UHF Frequencies
*Easy to Assemble and Install*High Quality Stainless Steel and Chrome Plated Components
*Mounts on 1 1/4 - 2" Mast Pipe*Antenna Connection:SO-239
