lexmedic157
So I decided to make an attempt to make a scanner antenna. Went to Radioshack and bought a chassis mount, and some brass wire (couldn't find small enough single strand copper wire). I primarily use UHF and had a hard time getting a couple frequencies at the extremes of the county. So here I went.
I cut 4 six inch lengths of brass, put ring terminals on the ends of them and nut and bolted them to bolt holes on the edges of the chassis, and bent them down to 45 degrees. I then cut on six inch and one 12 inch section for the vertical. Had a little difficulty mounting the vertical (please let me know the best way to get it on the chassis). Attached it all up and it seems to work pretty well.
Question... what can I do to optimize this setup, and will I get better reception with the 6 inch vertical or the 12 (keeping the 6 inch radials)?
I also bought one of those eBay J-poles (not knowing better), and surprise, surprise it didn't work any better outside than the rubber duck antenna in the house. So I searched a bit, dissected the antenna and cut it to spec, and surprise it works pretty well for just being old school TV antenna wire.
Anyway, I am totally clueless at all the is ham radio stuff, but I think I'm slowly getting addicted!
