Now where did that picture come from? I must be reading with my eyes closed! Now we're getting somewhere, a 12" element tells me it's operating range lies centered around 450MHz. If you want accuracy take an accurate measurement and use this calculator.
N3DNO's Antenna calculator
You'll have to jig around with it a little, these calculators determine element length from frequency so enter a few around 450 until the measurements match or at least closely approximate as much as possible.
This doesn't look like anything a ham can handle, we don't have equipment for that band and a UHF antenna analyzer for our purposes only goes up to 450MHz and accuracy is not guaranteed at the edges of it's range.
Now we get to the bottom line, it's an excellent receive antenna (and rugged as they come) which is what I expect you may use it for so no real need to get picky about it. It'll cover a good chunk of UHF but the farther removed from 450MHz the more it's directional characteristics are degraded, just so you should be aware of that little fact. Otherwise I say go for it, that antenna will be going strong when you are in your grave.
