-----> FYI <-----
I bought one of these and i must say i am NOT impressed.
I mounted it at the same height and facing the same direction as my ST2 antenna
and the ST2 works better then the yagi,(150mhZ - 156mhZ), while the ST2 is some what directional, the yagi is fully directional and pointed in the direction of the weakest stations i was
trying to pull in better, there was NO change and on about half of the stations it was worse.
May work better for others, but for me, I was not impressed.
Same cable type used on the ST2 was used on the yagi.
Same scanner used for both via a coax switch
It was a good side by side comparison with pretty much ALL thing the same
and the yagi did NOT provide the directional features i had hoped it would.
At the same price for both, i would buy another ST2 before this particular yagi.
