webley445
Nothing really to brag about I guess but figured I'd post it anyways.
followed these plans
SCANNER ANTENNA
Had some #14 solid, screws, and pieces of pcb board laying around so put it together and soldered up. Had a length of RG59 with a bnc on the end so used that. Its hooked up to a PRS500.
Aircraft freqs are coming in alot better than before. I had seem some other plans for a even more basic design where you are using the coax itself as the main element. Think it was on hamuniverse.com, anyways they said that it wasn't neccessary to remove the insulation so I didn't bother doing so on this one. But I am wondering if it is detrimental to do so? Would it give any improvement?
SCANNER ANTENNA
