Caveat--I'm a total electronics/hardware idiot here, so please be kind.
Anyway, I finally finished installing my new PAR EF SWL antenna, and (I believe) actually even did the grounding thing right. I have it attached with a 12 foot coax cable to my Icom R-75, and it works great, although I guess I thought it might bring in more "tropical" stations instead of simply making the evangelical stations come in clearer.
Anyhoo, I was wondering whether, with the use of some kind of coax-to-BNC adaptor, I could use this same antenna with my PSR 500 scanner? I realize there would probably be overload issues, but, in general, do you think this would help improve the range of reception more than the Diamond rubber duck and RS 800MHz antennas I've been using?
I know I could easily find out myself by buying the adaptor and trying it, but thought I might get your input first. I have the PAR SWL antenna wire attached to the matchbox, which is screwed into my basement window sill. I am using the full length of the included 45' wire, running 'straight" (i.e., not L) to a tree. The wire reaches a maximum height of around 6' at the tree. I have it grounded via a copper cable from the proper matchbox connector running to a 8' ground rod.
Note that I do not wish to install any more antennas at this point--this one is quite enough.
Thanks in advance!
Suzie
Thanks in advance!
Suzie
