scanaholic
I have a Shack Pro-433 with an antenna, I can't even recall the name of it. It is a good one, flexible but thin. A skinny type rubber duck antenna. Anyway, when there is a weak signal on it, if I walk up to the radio and put my hand at the base of the antenna, the signal nearly triples! What could I do to keep the signal that good without having to hold the bottom of the antenna? It makes me think some grounding isn't right about the antenna or radio itself.
Thanks for any input.
