JRM5204
I have the cheap RS antenna mounted in my attic fed with decent cable and it works good on VHF-HI and UHF-T but not so good on 800MHz. I wan't to hook this antenna up to atleast two scanners maybe three. I ran my coax down from the attic through the walls into my basement. I only have enough room for one cable and can't find anywhere else to run a another cable through the walls (older home two solid fire walls and the rest plaster) and I don't want to run a line outside so I am going to use a splitter. I read the sticky above and it didn't really help on picking one. I didn't see the RF Systems SP-3 splitter/combiner sold by Universal Radio. Has anyone used or use the SP-3 splitter/combiner?
Next I want to use a pre amp in front of the splitter to make up for any loss and get a boost on 800MHz. I know the pros and cons of using a pre amp, I have used GRE & Uniden pre amps for years. I just broke my GRE super amplifier 3001 so I have to get a new one. I am just thinking about getting the newer GRE but any suggetions on any other pre amps that cover VHF to 900MHz?
I think if I get a decent splitter and pre amp I will be happy but how if I got two splitter/combiners and hooked up a second antenna on the other side of my attic like a 800MHz Yagi to improve reception on 800MHz? Would that work or make the reception even poorer?
Thanks,
Joe
Thanks,
Joe
