MetalCarnage
I have a Grand Prix running a BCD796T with a maxrad antenna. I usually use the antenna to listen to 800mhz systems which it works very well. I also listen to a 140mhz system which the antenna picks up well but doesnt get the best range. I have an identical mount and identical antenna laying around and a BNC T-Connector and was wondering if i hooked them both into the scanner running them at the same time, would it help with reception at all? I was thinking since the antennas are not mounted at the highest point of the car and may suffer from signal degradation depending on the angle of the car in reference to the signal source?
Could this possibly help a little, or is there factors that would actually do the opposite and make the signal worse?
