xwindows2
I have a grundig s750 portable,put up a long wire outside
82ft of speaker wire 16ga about 30 ft above ground fed with rg8x-mini
I dont have a matching transformer between ant. and feed line
not sure what type of balun to use
win radio sells a long wire balun
not sure if i need 4:1 or 9:1 or i could use a 75 to 300 ohm
the reception is good but tons of noise on 40 meters
thank you
thank you
