Big thanks first to prcguy for posting up the project that he designed a while back. See the thread below for all the details of construction.
http://forums.radioreference.com/antennas-coax-forum/109144-4-bay-vhf-dipole-array-project.html
I just changed the demensions for UHF with a little exception and the rest is basically the same. I built it for a center frequency of 467.000MHz. I ended up having to cut the elements a bit shorter than what I calculated for the given frequency, perhaps I was off a bit on the phasing harness. I didn't alter those except they were cut per the design for 467MHz. I basically tuned each dipole individually the best I could with a radio, swr meter and a couple 8ft lenths of RG8X 50ohm cable connecting the two. Each dipole showed the same charastics, it wanted to be shorter than the calculated lenth. Perhaps it wanted to be a bit longer, I don't know and I didn't have any more copper pipe around so I started trimming with good results on the swr meter. I tuned the other three dipoles the same way. I then tested two of the dipoles connedted to a aluminum extendo painting roller out in the yard and that went well. Then I tested all 4 mounted and spaced correctly on a 10ft piece of 1" steel conduit and it tuned right up.
I also used 50 ohm RG8X for the phasing harness with F connectors and common cable TV spliters. I need to get a couple more smaller spliters to clean it up a bit. I painted it grey primer and put some caps on the elements with weep holes in the bottom caps. Hot glued the lug connections were the coax from the phase cable attaches to the elements. I had the antenna jammed into the ground surrounded by trees and it was receiving nearly as well as the tram antenna up on the roof.
I did 3 swr tests with the antenna to verify the swr results I was getting and the general performance. I tested the antenna from 440-480MHz outside in the yard feed with short runs of RG8X, then as a two-pole array in the attic for a few weeks feed with 12ft of beldon 9913, and finally on my roof feed with about 40ft of LMR400. All the swr results were nearly the same. Between 440-480 the highest swr was 1.8:1 which was at 440MHz. It has nearly a flat swr from 444-449 the varies a bit thru 455 then is nearly flat again thru 480. I can't explain it but I'm not complaining. It receives better than the tram did mounted in the same location about 10ft lower. I'm pretty happy with it so far. Some pics below.
