Just for kicks I hooked the last port on a Stridsberg 4 port multicoupler fed with a RS discone that is about 30 ' high that I use for feeding 3 scanners, to a DTV converter. I figured it wouldn't be so hot because of the impedance mismatch and some concern that I was told TV is usually horizontally polarized.
Guess what, it works better than one of those Winegard amplified "flying saucer" antennas mounted about 4 feet below the discone. Channel 59 that the winegard cannot see comes in fine with the discone.
Just thought I would throw that out there if anyone has a discone laying around or already up to give it a try instead of buying a TV-only antenna. I even found a BNC male to F female adapter that made the connection easy---
