Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
Old 01-01-2010, 9:55 PM
mcscanner's Avatar
Default Scanner Ant - Looking for article
Looking for the URL or article I used to build the attached scanner antenna. Vertical is 19 inches for the chassis connector to the tip. Plans called for UHF connector and 10 or 12 Ga wire. I used 14 Ga romex on bnc connector strictly for indoor use. Recommended for use on 150/450/800 bands. Antenna analyzer does indicate appropriate characteristic near 150 and 450, but analyzer does not cover 800. Seems to work well for what I listen to in the Grapevine, TX area.
Originally I thought I found the article in RR links to Wiki a couple of years back, but the only thing I found was the off-set vertical dipole today.
Any help would be appreciated.
The road goes on forever and the party never ends...
Old 01-02-2010, 8:05 AM
N0IU's Avatar
Since the vertical piece is 19", that would make it a 2 meter quarter wave ground plane. Here is a link to just one of thousands of articles on building a 2 meter version: BUILD A GROUND PLANE ANTENNA FOR 2 METERS AND MORE - SIMPLE AND EASY!
As far as making it into a multi-band antenna, I have not been able to locate any information on that... yet!
Scott - NĜIU
Old 01-02-2010, 10:06 AM
n4yek's Avatar
I have the article saved on my computer, but I don't have the URL.
The size of it, being that I saved it as a PDF file, prevents me from uploading it on RR due to size restrictions. PM me your e-mail and I will e-mail it to you.
Danny Harp Jr.
HAM Radio Operator: N4YEK
Old 01-02-2010, 10:28 AM
mcscanner's Avatar
Scott,
Thanks, I spend about an hour looking at all the different 2m construction articles. This one was simple and different. Concept was to place the different vertical elements for 450 and 800 so they would all play well together. I can't say that it works better, but it was simple and easy. I could reverse engineer what I did, but I was hoping someone had the link or article.
Old 01-02-2010, 1:00 PM
n4yek's Avatar
Sent to your email.
Have a good day.
Here is a link to my webpage where I have uploaded the article in question. I don't know the original URL for this and I am NOT taking credit for the design in any way.
http://www.qsl.net/n4yek/scanner/antenna.pdf
Danny Harp Jr.
Old 01-02-2010, 2:02 PM
Look for the "Copper Cactus".
I don't know the URL, but that is what your antenna looks like.
You can make the copper cactus with any bands you want from VHF low to SHF if you wanted.
Old 01-02-2010, 2:34 PM
mcscanner's Avatar
Default Thanks!
n4yek sent the file, it is what I was looking for.
I tried 'copper cactus' and several other word combinations. Nothing was working for me. It seemed to have disappeared from the face of the internet.
Thanks to all
Old 01-03-2010, 8:29 PM
SCANNER ANTENNA
Old 01-03-2010, 11:27 PM
Good information n4yeks!
Can anyone explain the loops at the ends of the elements to me? Are they needed electrically or just so you don't poke your eyes out?
Thanks,
HCH
Old 01-03-2010, 11:39 PM
hoser147's Avatar
Hal, check out the pic in post 1
Good Scanning Hser
http://www.radioreference.com/apps/audio/?feedId=165
Old 01-04-2010, 10:53 AM
OK. The loops are really not needed then. I though the top picture was another version of the drawing. At any rate, I think I'll start looking for some aluminum or stainless rod.
Thanks to all for the drawing and the information.
HCH
