Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
Old 07-16-2011, 8:15 PM
Default please identify this connector and help me decide the mount and antenna
I am trying to decide which antenna and mount I need for my Kenwood Tk-880. My range is 450-470. I live in a shore community with no major hills. I took a picture of the female connector since i am not sure which male connector I need.
Wide band
Maxrad MWU4002S [MWU4002S] - $39.95 : The Antenna Farm :: , Your Two Way Radio Source!
High Gain
Tram 1174 [1174] - $16.95 : The Antenna Farm :: , Your Two Way Radio Source!
Magnet mount With pl-295 connector
Tram 1235 [Tram 1235] - $16.95 : The Antenna Farm :: , Your Two Way Radio Source!
Thank you
Vicki
Vicki
Member of Pt. Boro FA Squad 35
BC350A, pro-97, EX560-XLS, Tk-880
Old 07-16-2011, 8:30 PM
Hi Vicki - that is an SO-239 connector other wise known as the uhf female.
The uhf male mate is the PL-259.
I have used the Maxrad MWU4002 and it is a great performing antenna.
Just make sure all 3 allen screws are tightened down(they come a little
loose) and it will last you forever and perform well.
fineshot1
NJ USA
Old 07-17-2011, 8:39 AM
Thank you so much.
Vicki
Old 07-17-2011, 10:30 AM
First off if your using the radio in UHF then you should dump that connector, in commercial world that connector is referred to as a PL-258, SO-239 is RadioShack/HAM lingo. The connector is rated I think for use up to VHF applications and was originally created for analog TV reception and somehow made its way into commercial radios. I love Kenwood Radios and have Many mobiles with that connector. I have a TK-760G that has the pigtail, I lopped off that connector and went back with a TYPE N Female, Type N connectors are rated for use at SHF which is best for low loss coaxial connections. Do you Really need Type N? No but, but they are better, and rated for UHF, PL's are not why Kenwood did it is unknown, probably cheaper. Also on the antenna mount: if you go with a NMO style mount just know that NOT all NMO mounts are rated for UHF and SHF. Rule of thumb is NMO mounts that have a large center contact button it is Not Rated for UHF-SHF use.
kg4uad
Old 07-17-2011, 10:56 AM
Vicki - here is more info if needed.
UHF connector - Wikipedia, the free encyclopedia
fineshot1
NJ USA
Old 07-17-2011, 3:55 PM
n4yek's Avatar
kg4uad
A PL-258 is a barrel connector to connect two PL-259's together, what he had pictured is called an SO-239 connector.
http://cdn.sigma.octopart.com/855730...8PL-258%29.jpg
http://www.premiere-electronics.net/store/pl258.html
Danny Harp Jr.
HAM Radio Operator: N4YEK
Old 07-18-2011, 6:21 AM
PL= Plug, SO=Socket
Old 07-20-2011, 4:26 PM
Thanks everyone I just got the software and data cable today so I just need the antenna. Again thanks for the advice.
Vicki
Old 07-20-2011, 9:46 PM
Question a little confused
Kg4uad: (or anyone)
Are you saying i need a ground plane mount or is that something else. I saw some adapters to make a nmo uhf compatible. I'm getting confused. Please tell me if any of these will work for my 450-470, pl-295 (i can upgrade the connectors later), 45 watt, uhf set-up.
mount
Maxrad NMO Antenna Magnet Mount with PL-259 Conn NEW | eBay
antenna
Antenex UHF Whip Antenna for Mobile Two Way Radios NEW | eBay
Do i need an adapter?
Antenna Mount Adapters : The Antenna Farm :: , Your Two Way Radio Source!
Wow! The antenna has been the most difficult part in the set-up of my radio
Thanks again!
Vicki
Old 07-21-2011, 5:07 AM
The nmo mag mounts (first and second kinks) will work just fine. You do not need a ground plane mount.
The metal of your vehicle will serve as the ground plane. If this is for indoors then use a cookie sheet
or some flat magnetic metal to put the mag mount on, perhaps the top of a filing cabinet or similar.
The antenna's you linked will both work fine.
You will not need an adapter as long as a PL-259 connector is on the end of the antenna cable.
Those adapters you linked are to convert an nmo mount to other mount types which you will not need.
fineshot1
NJ USA
Old 07-21-2011, 6:48 AM
Ok, thank you fineshot1. I am ready to put in my order.
Vicki
