FireBall517
I was wanting to use some cable tv wire for an antenna. The coax is hung on telephone poles with about 50 ft of wire, across and not plugged in to the main cable box.(We never had cable when we moved in, directv...) I have a 5 ft cable thtat is attached with aligators on both sides, and wanted to clip one end to the antenna and other end to the pin in the middle. I am using a Grundig G8 II Traveler( If your wondering why i was using alaigator clips). Thanks in advance...
