Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
Old 10-08-2011, 10:07 PM
Default Radio Shack 20-176 vs Antennacraft ST3
Does Antennacraft make the Radio Shack 20-176? If not which is the best quality? Which will best stand up to the elements of Florida? I would definitely take it down if a hurricane came through here. Mainly interested in the build quality and which one is built tougher?
Thank You all in advance for your input
Tom
Old 10-12-2011, 12:12 AM
Anyone any input?
Old 10-12-2011, 8:11 AM
Rt169Radio's Avatar
I do not think Antennacraft makes radioshack products.A good strong antenna would be the Diamond D-130J discone,another great antenna would be the Antennacraft ST2,but keep in mind that its made out of tv grade antenna stuff and not stainless steel like the D-130J.
Diamond D-130J D-130NJ Discone Antenna
Antennacraft ST2 Scanner Antenna, Antenna Craft ST-2
What freqs are you looking to listen too?
Old 10-12-2011, 10:58 AM
pdfdems286's Avatar
the radioshack discone <large one> is a pretty good all around antenna. the build quality suck's. i have one because i have the restriction's of an attic for my antenna space. with that being said, it does not hold up to any harsh wind's or other weather element's. it's made of cheap aluminum.
Old 10-12-2011, 1:37 PM
freqs's Avatar
I have a scantenna and I love it works well strong built .Picks up well but not on 800 . I have received many skips all summer .Average I get 60 plus mile range .I had the Radio Shack Discone it did pick up well but fell apart in a few years .3 years on old house 1 year on new home still works and no issues and no mod done to it
Old 10-13-2011, 1:52 PM
Just thought I would pass on this info. I contacted AntennaCraft and they say that the Radio Shack model is made by Antennacraft. They said it is the exact same antenna.
Old 10-13-2011, 2:33 PM
Rsmims's Avatar
Default Radio Shack Discone
I will agree that Radio Shack Discones are cheaply made. The radials are Stainless Steel tubing and will break VERY easily. That being said, the antennas receive a very broad spectrum, everything between 25 mhz thru 1.3 ghz, and I have 2 of them sitting atop a 50 foot tower.
The 1st install was stock, out of the package. 2 weeks later, I've got radials laying all over the yard after a big wind. So, I bought enough 1/4 inch solid stainless rod to replace all the radials, cut them to size, threaded the ends, and installed them with blue Locktite.
Those 2 antenna have now been in the air for 3 years, have survived 75 mph winds combined with below 0 temps, and I would put them up against ANY antenna out there. Non standard? Yes, but worth it. I use them to supply the 13 scanners for the feeds I provide here.
Why did I do this? Diamond mades a good antenna but is overpriced.
My 2 cents worth.
It's all Mind over Matter....If you don't Mind....It don't Matter.
10-BC350A, 4-BCT8, 4-BC560XLT, 3-Pro77A, 2-Pro7A, 2-Pro48
Old 10-13-2011, 3:14 PM
i have found the best for 800 use is the bs800s-c, comtelco- s- series from (RFWIZ.COM)
Old 10-13-2011, 3:20 PM
gmclam's Avatar
Smile discone vs discone
I use the RS discone and it works good for me. I agree that it is quite delicate to say the least. I have purchased and installed discones from ScannerMaster for others, and I will say they are a lot more rugged. If I was doing it again, I'd definitely get the more rugged version, especially if in an area with lots of weather. Performance wise, they are the same.
PRO-95 | PRO-10 | PRO-97 | PRO-77 | PRO-92 | PSR-300 | PSR-310
Old 10-13-2011, 3:54 PM
Why is everybody talking about discones?? This thread is about the sputnik type antenna Antennacraft ST3 and Radio Shack 20-176. Please keep on topic
Thanks Tom
Old 10-13-2011, 4:07 PM
Rt169Radio's Avatar
Interesting to know that.
Old 10-13-2011, 7:05 PM
ermin's Avatar
Wink
Tom
I had one outside in West Palm Beach and it rusted out in less than 3 years. Have another on in my attic for over 12 years now. Won't last long near the ocean.
73
Ermin
"Never eat more than you can lift" -- Miss Piggy
Old 10-13-2011, 8:43 PM
73
Ermin
I think I am far enough inland to avoid this problem. But I may consider painting it.
Old 10-13-2011, 9:33 PM
N8IAA's Avatar
Thanks Tom
ST3/RS sputnik antenna= discone.
Larry
Digital/Analog scanning and hamming
Old 10-14-2011, 12:06 AM
Larry
I started this thread as a comparison between the RS 20-176 and Antennacraft ST3 not the ST4 or ST2. The ST3 is more like a Ground Plane not a discone.
