Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
Old 02-21-2012, 12:16 PM
jassing's Avatar
Send a message via ICQ to jassing Send a message via AIM to jassing Send a message via MSN to jassing Send a message via Yahoo to jassing Send a message via Skype™ to jassing
Default paint an antenna?
For purely vain/cosmetic reasons, I want to paint a chrome antenna flat black.
questions tho -- will painting substantially lower the performance (rx/tx)? (uhf 460mhz)
Antenna in question is either going to be a whip or center loaded...
-j
Old 02-21-2012, 12:32 PM
n1ti's Avatar
Send a message via AIM to n1ti
I have painted several mobile antennas in the past to reduce visibility...mostly with flat black Krylon. Just test the paint before you spray and be sure that it doesn't have conductive metal particles in it (spray onto to a non-conductive paper and then measure resistance at all scales of your VOM. If in the 100's of megohms you still be ok. If a direct short....masking will cure.. To be on the safe side, mask off your loading coils before spraying to not cause a change of impedance to the coil or a short around the coil from whip section to whip section. . A brush-on enamel should be ok too and may be a little more durable too as you hit insects and road grime.
Tim, N1TI
Mattapoisett, MA
Old 02-21-2012, 7:33 PM
jassing's Avatar
Great thanks!
That's why I want to paint it to reduce the obvious "Radio inside" stickers. This will be the only antenna that doesn't have a quick release for storage in the toolbox when at mall/walmart, etc.
Good tip on the test -- I hadn't thought of rattle paint as being conductive... and definately will mask off the coil...
-j
Old 02-21-2012, 10:52 PM
ramal121's Avatar
I've painted chrome whips black also without problems. When I want to test a paint for an antenna, I spray it on an inert object like a paper plate and then pop it into the microwave oven. If the paint stays cool it is RF transparent. If it heats up, don't use it.
The fat one will never die! (http://www.kfat.com/)
Old 02-21-2012, 11:51 PM
eagle15's Avatar
I don't want to sound like an idiot but do you let the paint dry before microwaving?
I am here: http://maps.google.com/maps?ll=35.473651,-97.396988
Old 02-21-2012, 11:53 PM
jassing's Avatar
well.. we've got a microwave just aching to do a test like that! (it's done the "cd" thing one too many times, but still works more/less.)
Old 02-22-2012, 10:45 AM
I did the CD thing ONCE! After the blue smoke cleared and the smoke detectors quit screaming, the wife let me know that experiment wouldn't happen again.....
K9WG - Greenfield Indiana USA
SkyWarn
ARES
Old 02-22-2012, 12:21 PM
jassing's Avatar
ha! I've got a keeper -- the cd idea was hers..
