Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas - For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
Old 02-22-2012, 8:22 PM
Default Great investment Ramsey's All Band, HF, VHF & UHF Active antenna
Best investment ever for a Antenna
Features:
Acts like a 60ft guide wire antenna great for those people living in a deed restricted area or a apartment complex
Frequency operations : 1 MHz to 800 MHz
Bandwidth : > 800 MHz
Gain : 1 to 150 MHz > 20db
150 to 400 > 12 db
400 to 500 > 10 db
500 to 800 > 5 db
RF input & RF output BNC connections
Power supply 9 to 20 VDC with internal supply 9volt battery
The only down fall is to anyone that you have to build it yourself.
Ma/com radio P7100ip, Ma/com base station 800 mhz Edacs,Pro-162,Pro-83,IBQ frequency counter, SS70WT Speech/descrambler, Ma/com base controller station Bsc-1000.
Old 02-22-2012, 8:27 PM
Wiki Admin Emeritus
With that much bandwidth and gain, you're almost sure to get some overloading issues in urban areas (not to mention an increase in background noise, which is almost as bad). Now if you add some preselection in front before the amplifier, now you're talking, but right now, this is an invitation to a disappointment...best regards..Mike
