Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
Old 02-29-2012, 5:35 PM
Default Diamond RH77CA Thumbs DOWN
Slapped the above antenna on my GRE 500 this morning...Gre 800mhz antenna gave me 3 solid and 4 flashing bars at all time...Attached the Diamond and BAM, 0 bars flashing 1...
Left it on for 15 minutes and took it off...Sold it...Absolutely no good for my rural area...Only thing that came in was NOAA at 5 bars..
As soon as I reattached the GRE 800mhz antenna, right back in action...Amazing how much difference there can be in antennas...I am going to try a Condor next and or perhaps a Watson...More or less just doing it for an experiment...
Old 02-29-2012, 9:26 PM
You are comparing apples and oranges. The Diamond RH77CA is a dual band 144mhz/440mhz antenna. It will work good for VHF/UHF. It will not outperform an 800mhz antenna on 800mhz.
Old 02-29-2012, 10:58 PM
Rt169Radio's Avatar
Well a dedicated antenna for a certain freq band would work better then a antenna designed to cover more then one band.
Old 03-01-2012, 9:42 AM
Research research research!
Old 03-01-2012, 11:46 AM
ridgescan's Avatar
Diamond RH77CA Product Reviews
32 reviews and almost a perfect score
also those GRE's from what I have learned, are crazy sensitive and may not like too much antenna.
Unidens BC785D, BC350A on a D130J
'54 Hallicrafters SX-88 #127, Icoms R71A&R75 on 50' random wire @40' SW will never die
RS Pro 2066 in the truck to glassmount tribander
Old 03-01-2012, 1:07 PM
"The Diamond RH77CA is an HT antenna for transmit on 2 meters and 440 MHz. It is a 1/4 wave on 2 meters and a 1/2 wave on 440. It can additionally receive these bands: 120, 150, 300, 450, 800 and 900 MHz. As a result of this exceptional coverage, we actually sell more of these antennas to scanner listeners than hams! It is a favorite model for scanner enthusiasts, and for those using the new breed of wideband handheld radios."
Old 02-11-2013, 11:38 AM
Allan_Love_Jr's Avatar
Send a message via Yahoo to Allan_Love_Jr
I still have mine. And it is one of the best damn Antenna's to date. Especially when monitoring the Rail band. Perfect Antenna.
Allan Love Jr
Old 02-11-2013, 11:58 AM
n5ims's Avatar
You're pointing out what the marketing department added after engineering was done. They probably checked with their engineering team and asked if the antenna would pick up a signal on those other bands if it was strong enough and engineering said "Sure, if the signal was strong enough." so marketing added it as a feature. As I like to say "Works on" doesn't equal "Works well on", it simply means it doesn't filter out those signals.
Old 02-11-2013, 10:37 PM
RadioDitch's Avatar
Mine works just fine on all bands on my PSR-800, BCD396XT, and BC346XT. No complaints at all. And that's in the mountains of PA...
73, W2MJR/EI7D
EMT/Railfan/Certified Nerd
Union County, NJ - Morgan County, WV - Baldoyle, IE
Confucius Say: "Communications techs do it on-air."
Old 02-11-2013, 10:42 PM
Ronaldski's Avatar
Dont forget those GRE/RS radios do terrible when they get overloaded with too much signal.
Example - http://www.youtube.com/watch?v=UgminOVS2no
Old 02-12-2013, 3:36 AM
n8zcc's Avatar
Did you copy this: Diamond RH77CA Amateur HT Antenna
I agree, the RH77 is an outstanding antenna, I use it on my PRO-106 and it does the job.
73 de n8zcc
Bytes are cheap so drop those acronyms.
Old 02-16-2013, 5:50 PM
Default Can somebody please explain this..
Years ago I bought one of those Diamond RH77CA antennas for my PRO-106 scanner. I had to sell the scanner and sold with with what antennas I could find. Last week the kid cleaned out my car and found this antenna under a seat. Using the supplied SMA to BNC adaptor that came with my newer Uniden BCD396xt scanner I put this antenna on the scanner.
So my question is, why does this BNC version of the antenna totally outperform the SMA version that I purchased when I bought the Uniden scanner?
Old 02-16-2013, 10:12 PM
k3cfc's Avatar
I have a sportcat scanner and replaced the original telescoping antenna with my 2 meter 440 diamond antenna and i can say what a difference. soooo i am getting another for my scanner.
K3CFC
Don't confuse my personality with my attitude.
My personality is who I am.
My attitude depends on who you are.
Old 02-17-2013, 11:23 AM
What model number is the 2 meter 440? I am all for getting some specifically tuned antennas as opposed to wide band.
