| Scanner / Receiver Antennas For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld. |
06-07-2012, 1:29 AM
Diamond Discone or Omni X
I want to buy a new antenna because I am not happy with the performance of my Scantenna. I am thinking of buying either the Diamond Discone with the N Connector or an Omni X. I monitor VHF Low 33.70 to be exact because some of the counties around me are still using it. My home county is on UHF. I have no need for VHF High or 800. The antenna will be outside on a 20' mast and will be fed with 30' of LMR 400. Will the Omni X do VHF Low? If not I guess it would be wiser to go with the Discone? Any help would be appreciated.
PA FFI., BVRT, HMA, HMO Wild-land Certified
Scanners: Uniden BCD996XT, BCT15X, BCT8, BC350A
Antennas: Diamond RH77CA, Diamond X50NA, Radio Shack Discone, Antennacraft ST-2, Austin Spectra, MONR-33
06-07-2012, 3:23 AM
The Diamond Discone antenna would probably do better than the Omni X, simply because it's designed to cover the 33.7 Mhz frequency range (has that long top element). Would it perform better than the antenna you are using now? Beats me, but maybe.
- 'Doc
06-07-2012, 5:15 AM
Wow, I'm surprised 30Mhz is still used in the States! It must be horribly noisy in town.
Anyway, I have the Diamond D-130J discone and have done some testing on it. The antenna works relatively well on frequencies from about 100Mhz up to 1.3Ghz (Low VSWR and -3 to unity gain). However, the discone elements are not long enough on their own for frequencies below about 100Mhz. The top vertical element is actually a loaded 6m (50Mhz) resonator, which provides a reasonably low VSWR on a very narrow band (about 1Mhz wide) on 50Mhz. I have put a return loss bridge and a sweep generator on the antenna and it does offer low VSWR on most frequencies above 100Mhz. Below 50Mhz though, the antenna works about as efficiently a piece of wet string.. On 30Mhz you won't hear much at all with the D130j, unless it is a strong signal already..
You could try one of these:
http://www.cometantenna.com/pdfs/UHV-4_manual.pdf
Gives you all the bands you are interested in..
What can go wrong, will go wrong!
FuncubeDongle Pro+ - PSR600 - PSR500 - BCD996XT - BCD396XT - TM9155 - IC-208H, amongst others :-)
06-07-2012, 5:31 AM
Even the Omni X isn't going to do well with low band,it's design is 118 and above.
06-07-2012, 6:34 AM
I'm surprised the Scantenna didn't perform well. I always had good look with them even down into low band.
06-07-2012, 7:55 AM
Maybe there is something wrong with his Scantenna or coax?
06-07-2012, 12:00 PM
I don't think you will find a discone design to perform better than a ST2 on Lo Band. I have used both, Discone and Dipole design.My old 5094A Channel Master and ST2 have performed the best in that range. Like Rt169Radio mentioned you might want to do some investigation on the antenna and coax.
06-07-2012, 1:40 PM
I may have done something wrong with the Scantenna. I just thought I should have been picking up more of Westmoreland County which is on 33.70 better than what I was. I used the RG6 that came with the antenna as far as the coax goes but I plan on upgrading to LMR 400.
06-07-2012, 2:16 PM
Doublecheck the balun, or perhaps try a replacement like the RS #15-1140. The baluns shouldn't be too lossy at vhf low, so maybe yours is just kaput. For UHF / 800 mhz, some might want to try several higher-quality baluns with less loss - the tv forum guys seem to prefer blonder-tongue, channel master, etc....
06-07-2012, 7:09 PM
I have a d130j on the roof that pulls in the CHP in the 42megs from all over the bay area. I cannot figure out where exactly the transmitter sites are, but from western San Francisco, I can hear San Mateo County, Marin, Alameda, Hayward, Santa Rosa, and even Fairfield out 60 miles. All different signal strengths too. I think that's pretty good for vhf low.
EDIT-I did a couple videos  just wanted to show that the d130j isn't such a "wet noodle" on vhf lo IMO
the CHP in SF, Redwood City, Hayward, Oakland and Marin
http://www.youtube.com/watch?v=ZRPZQYDvs5E
some park rangers out in the east bay
http://www.youtube.com/watch?v=L0BG46C6Vus
Unidens BC785D, BC350A on a D130J
'54 Hallicrafters SX-88 #127, Icoms R71A&R75 on 50' random wire @40' SW will never die
RS Pro 2066 in the truck to glassmount tribander
