Originally Posted by petty4305
Hey everbody, I just bought a WEP-2000 thru glass dual band(2m/70cm) antenna. I installed it on one of the rear side windows. Every time I pulled into the garage it would hit so I cut some off. I cut about 2 1/2in. off. My question is; will that much effect the performance of the antenna?
Reportedly, glass antennas are not preferred for performance. I can't really say because I've never owned one. My friends tell me that their performance is substandard when compared with other ones.
I think my friend told me the better version of a glass antenna might have a ground on it. I prefer using magnetic mounts even though the coax runs through the door opening. If you must use this method, find a door that opened less frequent.
