Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
Old 01-11-2013, 1:32 PM
GKolo's Avatar
Default Radial off my Diamond discone
How quick do i need to get the radial back in my antenna > Is it going to make a huge difference ?
It fell off in a wind storm lastnight and its kind of a project to drop the antenna so i can work on it.
''Life's tough ........ it's even tougher if you're stupid.'' -- John Wayne
Old 01-11-2013, 2:38 PM
I would think that putting it back should be done as soon as 'practical'/possible. I doubt if there's a huge absolute need for it immediately though. This time of year, where I live, would probably mean waiting till it got warmer... YMMV, naturally.
- 'Doc
Old 01-13-2013, 9:59 PM
depending how many you lost, the more missing the less your dicone will perform.
Old 01-14-2013, 8:10 AM
Rt169Radio's Avatar
I don't think one radial will make a difference, but if you can get it back on I would do it.
Old 01-15-2013, 9:29 AM
GKolo's Avatar
Only one is off, But it is such a pain to lean the mast over to fix it.
If it ever quits raining i will get motivated and start on it.
Old 01-15-2013, 9:37 AM
ridgescan's Avatar
If you're like me, there will be a one man radial band in your brain-first he will march around with a baton, then he will run ear to ear crashing symbols. Then he will practice his latest drum solo while tooting a kazoo. Until you fix it
Unidens BC785D, BC350A on a D130J
'54 Hallicrafters SX-88 #127, Icoms R71A&R75 on 50' random wire @40' SW will never die
RS Pro 2066 in the truck to glassmount tribander
Old 01-15-2013, 10:13 AM
KI4VBR's Avatar
Default Too Funny!
I cracked up reading that, but you know.....it is true at times! It is like one of those songs you just cant get out of your head.....and its even worse because you hate that particular song.
As far as the antenna, I cant remember if all of the radials are the same length on a discone. If that is the case, I think you may not be able to notice the difference in signals.....even using an S-meter.
If you were transmitting through the discone, it would be a different story. You would probably notice it more on the lower bands like 6 meters, allthough your SWR may only have a slight change.
Vince
Listening to: Icom 756Pro3, 706mk2G,730, Icom 2200H, RX7 Govt/Export, FunCube SDR, Yaseu 857D, Flex3000 SDR, 811h, FT-60 dual band, 396XT, 895XLT, HP1, Pro-95, Pro-97, Stridsberg Active Multi-Coupler
Old 01-15-2013, 10:31 AM
One radial will probably go unnoticed on tx or rx. A Disconed needs about 16 top and 16 bottom elements to get the maximum performance or similar to one made of sheet metal. The common designs with only 6 or 8 radials on the top and bottom are a compromise to start with so don't hurt yourself trying to fix it in a hurry.
prcguy
Old 01-15-2013, 12:03 PM
GKolo's Avatar
Its all the inside work that is going to suck, I have to unload the desk with books and radios on it to get to the corner where the coax comes thru the wall, I have to make sure it gets outside safe, take the coax out of all the little holder up things, droping the mast will take 2 minutes, another 2 minutes to put the radial back on, 10 minutes to check the connections and then put it all back together....the desk part is the worst.
Old 01-15-2013, 8:39 PM
next time put a preamp at the jonction of the mast and the house, easier that way :P
Old 01-16-2013, 8:19 AM
GKolo's Avatar
i was going to but didnt have a way to power it.
Old 01-20-2013, 3:30 PM
GKolo's Avatar
Ok i got energetic today and fixed the radial, I also moved it about 18 inches higher on the mast, So i should be back in service. I was going to put my homebrew antenna on the mast just under the Diamond but the elements wouldnt line up right to make it work.
Old 01-20-2013, 5:52 PM
Hey, you got part of it done, that's good. Now back to the drawing board for that other antenna. There's always something, ain't there?
- 'Doc
Old 01-20-2013, 5:56 PM
GKolo's Avatar
I had the homebrew up but there is a tree limb to close for comfort.
