| Scanner / Receiver Antennas For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld. |
03-19-2013, 3:51 AM
Outdoor Antenna's
I am interested in building an outdoor antenna, Possibly a 50ft antenna, What could I use to build the structure and what type of antenna should I use,
03-19-2013, 4:44 AM
Re: Outdoor Antenna's
That depends on what you want to listen to.
03-19-2013, 10:31 AM
Until your question gets moved - I'm thinking you'll most likely need to purchase and assemble a tower for that kind of height. And you'll need to have very good lightning protection. But there are others with more knowledge on the subject than me.
04-07-2013, 1:41 PM
I -just- put up a skyband on top of a Radio Shack 10 foot pole. It's pretty good. My pro 197 gets T-UHF better than VHF. I have to put the attenuator to use on VHF now. If you wanna go up top of a roof, be prepared for wind. I did, then it sleeted out for 20 minutes. Point is--whatever you get, make sure it's what you want. It's a pain in the neck going back up to adjust anything. I also have a Ferret up there opposite of the skyband. $300.00 for that stick, works great. But, as I said. " It's a real pain to work on a roof." Noone I know has the coconuts to do what I just did. All the brave souls that go work on towers has my upmost respect. And yes I used safety lines. 15 years ago I would not have, but time and experience taught me to be very-very careful.. Good luck, be safe!!
04-07-2013, 2:08 PM
Mainetrunk:
"If you wanna go up top of a roof, be prepared for wind. I did, then it sleeted out for 20 minutes. "
The performance of an antenna is inversely proportional to how nice the weather is. Every antenna I've installed on fair to nice days work fairly or junky. The antennas I put up in advance of a thunderstorm, in a snow squall, or a rainy afternoon prove to be the best performers throughout their lifecycle.
KC8ESL - Lake County Ohio
TM-V71A, IC-2410H, TS-130S, FT-530, BCD-396XT, PRO-96
04-07-2013, 2:11 PM
lol im in the long process of building me a tower off a pole i already have at my house. the light pole is up about 14' and im going to throw up 21 feet on top of that for a height of around 30 feet but i went ahead and bought me a set of mounts so that if/when i need to do service or add to it that i can just hopefully take the pole down someway and do what needs to be done to it from the ground.
BCT-15
BC-72xlt
Pro-106
04-07-2013, 4:45 PM
Check out the Tavern posts, Do it yourself section, Tilt over mast build, some good info and pics.
04-15-2013, 2:14 AM
Best place for Antenna
Well the idea sounds good, but I guess you can try out with 45ft or 48ft rather then 50ft. Actually a height less then 50ft works out perfectly. I also advice you to use aluminum or copper which would give stability and also good in terms of wind flow.
I also suggest you should take special care at the joints. You can refer few
How to Build an Antenna
DIY FM Broadcast Receiving Antenna | eHow.com
Antennas, Masts and Towers - Army Technology
