LIScanner101
I have a Channel Master Monitenna 5094A that I am trying to put in my attic due to the wicked winds we have gotten here on Long Island last couple years. It's about 10' tall so I know there's no way it's going to fit vertically. I am almost ready to put it up there and just tuck the bottom element down inside a wall (there'd be sheetrock on both sides) but this will leave several feet covered by something solid. I know this is going to affect the Rx capability but I think tilting the antenna sideways will be almost as bad - almost like a "six of these, half a dozen of the other" situations.
Here is the frequency coverage of this antenna:
Low band 30-50 Mhz
High band 148-175Mhz
UHF 450-470Mhz
UHF-T 470-512Mhz
UHF-HB 800-912Mhz
Nothing I currently monitor on Long Island is lower than 46MHz. Therefore, I was wondering if I can just cut-down the vertical elements a little to tune the low-end coverage to 46MHz? This will also give me a shorter antenna that would fit better in the attic.
Is there some formula I need to follow in order to determine the proper cut-down length of my Monitenna? I know with whips it's pretty straightforward, but with a fan dipole like the Monitenna it might be more complex...
Thanks,
-John
Low band 30-50 Mhz
UHF 450-470Mhz
UHF-T 470-512Mhz
UHF-HB 800-912Mhz
Thanks,
-John
