Any A/S MON Series experts out there…???
LIScanner101
Palm City FL
Hello! I have several old MON-Series mobile antennas (MONR33, MON-52 and MON-53). The instruction manuals that comes with them all show a #K-722 base coil. There are no specs for this coil, and there are no markings on any of the coils I have (except for the Antenna Specialists logo), but The Antenna Farm carries them, and their site shows them as:
“406-470MHz replacement coil for ASP7650 MOSAIC series antennas”
Under “MHz” it shows “406-470MHz”
I ALSO have an old A/S MON-58, which is basically the MON-52 whip with a base kit. HOWEVER, the instruction manual with the MON-58 shows a #K-222 coil, and the manual says “Marked 406-494MHz”, and the actual coil does have “406-494MHz” embossed in the top section of the plastic housing.
The upper whips for the MON-52 and the MON-58 are BOTH listed as #19-4645-1 in their respective manuals.
The MON-52 and the MON-58 are both rated for 25-1000MHz.
Now, here is my question:
If both antennas are rated for 25-1000MHz, and both antennas have the same exact main whip, then why would they have different base coils?????
_Wilson_
columbia Tn.
does the black housing look like the standard k-722 ? or is the surface smooth ? i might be wrong, but i think the K-222 is an older model, and the K-722 is an updated model.
LIScanner101
Palm City FL
The K222 I have has a metallic label around its upper perimeter, none on the K722.
The K222 is definitely smoother than the K722.
I still don't understand why they have different specs...
Maybe the specs in the actual A/S manual are accurate, and the specs on the Antenna Farm website are bogus (since he doesn't show a source for the data)?
_Wilson_
columbia Tn.
i'd go with the info from the A/S manual. what your describing sounds like the K-222 is an older model, and the K-722 is an update, i have one like the K-222 smooth surface and chrome strip you described. when you look inside the the bottom of the K-222 does it look like fiberglass, kinda white or lite yellow,or metal "like brass" ?
i have several base part numbers, and K-222 doesn't match any "strange"
LIScanner101
Palm City FL
I'll check out the undersides of both bases tomorrow. Thanks for sticking with me on this!
The bottom line is, only the K-222 coil has data supported by A/S as seen in the MON-58 manual, where it says 406-494MHz. There is no A/S bandwidth data for the K-722, at least none that I can find. I'd love to know what the specs are...
I guess I can try swapping them out on one of my MON-52 whips and see which one gives me better coverage.
_Wilson_
columbia Tn.
glad to help. i have some old paper work, with specs and model numbers, this info came from A/S Antenna Specailists Allen Group K-722 406mhz-470mhz, KT722 470mhz-512mhz, K-725 138mhz-174mhz, KH725 210mhz-230mhz.
i'd like to have the KT722, and the K-725
LIScanner101
Palm City FL
glad to help. i have some old paper work, with specs and model numbers, this info came from A/S Antenna Specialists Allen Group:
K-722 406mhz-470mhz
KT-722 470mhz-512mhz
K-725 138mhz-174mhz
KH-725 210mhz-230mhz
I'd like to have the KT-722, and the K-725.
Wow, thanks much! OK, I see that the bandwidth of the K-722 does indeed match what’s on The Antenna Farm’s website, so that’s good. Now I wonder why they use a different coil on the MON-58 than they do on the MON-52? Seems to me that they should be the same, since they both use the same main whip and the coverage is (was) advertised as being 25-1000MHz…I guess we’ll never know since A/S is long gone.
