Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
Old 11-09-2013, 3:21 PM
KC9VZV's Avatar
Default Using a discone without all 'arms' attached
I have had a discone antenna for about a year but I haven't gotten much use out of it because I don't really have space to mount it inside my attic and doing it outside is not doable for a variety of reasons. I was recently thinking: would it work to simply erect the discone inside (in the corner of my office) and not have all the "arms" attached to it? I obviously wouldn't get as good performance out of it, but I would imagine that it would be better than a rubber-ducky antenna.... I just want to make sure it won't be harmful to any of my equipment. Any thoughts would be appreciated!
Thanks!
Dan, kc9vzv
73,
Dan, KC9VZV
IPN Dispatcher: ILL043
Old 11-09-2013, 3:52 PM
wtp wtp is offline
Default its ok
sure performance suffers and it might become slightly directional (a guess) but i once tries mine with on e "arm" and one "leg" and it worked. try it you never know what may happen
Old 11-09-2013, 3:54 PM
KC9VZV's Avatar
Ok, thanks! I'll give it a try.
Dan
73,
Dan, KC9VZV
Old 11-09-2013, 3:56 PM
lep's Avatar
lep lep is offline
I assume you are talking about using the discone with a scanner for receive only. Unless it falls over on your FAX and accidentally sends a message I don't see any way it could be 'harmful to your equipment' since it is not radiating any energy.
Old 11-09-2013, 4:02 PM
KC9VZV's Avatar
Good point! If it falls over at all, we will have bigger problems than sending a fax accidentally!
73,
Dan, KC9VZV
Old 11-09-2013, 4:13 PM
ridgescan's Avatar
I'd be interested in learning how a discone would do without its groundplane.
Unidens BC785D,BC350A on a Diamond D130J @50'
'54 Hallicrafters SX-88 #127; Icoms R71A&R75; on the PAR to 45' n-s wire @45'
RS Pro 2066 in truck to glass mount tribander
Old 11-09-2013, 4:19 PM
KC9VZV's Avatar
I'll let you know once I try it!
73,
Dan, KC9VZV
Old 11-09-2013, 4:26 PM
wtp wtp is offline
Default quite a time ago
i was living alone and put mine on the dinning room table as a sick looking christmas tree (not recommended)
i think tinsel conducts so don't use it.
experiment and find out.
enjoy/
Old 11-09-2013, 4:58 PM
jhooten's Avatar
This one works quite well:
Hustler DCX: Ham & Amateur Radios - Equipment, Parts and Supply | AES
Jerry
I read it on the internet, so it must be true.
Old 11-09-2013, 5:06 PM
Originally Posted by jhooten View Post
I once had one of those (back in in early 1980's). In my opinion, it was the worst antenna I have ever used and it suprises me that it still exists. With only 3 disk and cone elements, and the common ones having 8, it is a compromise of a compromise. I have a commercial one with the recommended 12 disk and cone elements--much better.
The Hustler is particularly poor at 700/880 MHz due to the too large spacing in the separator between the disk and cone--keep in mind its design predates those bands. It may work work better at low band VHF but I use better antennas there.
Old 11-09-2013, 5:37 PM
I agree 100%. It probably doesn't even qualify as a Discone.
prcguy
Old 11-09-2013, 6:46 PM
jhooten's Avatar
With an antenna switch doing an A-B comparison between the DCX and the Rat Shack discone the 20 year old DCX gives consistently higher S meter readings on V-low, V-High, and UHF. I don't have anything on 800 with an S-Meter. The DCX has survives winds that have left the lower Rat Shack elements wrapped around the Mast or missing.
Did I mention it cost about a third as much?
It has done me so well I bought another at AES last trip to Las Vegas.
Jerry
