Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
Old 12-10-2013, 11:09 AM
kmh603's Avatar
Default Wide Band Mobile Scanner Antenna
I have read lots of posts in here and in different forum's. I am unable to find any good info on a mobile scanner antenna? I am looking for a Scanner Antenna that covers 136-174 (VHF) 380-560 (UHF) and 700/800. I do not want a scanner antenna that has "Unity dBi " I want one that has at least 3 dBi on all bands. I am also wanting a Spring Loaded Antenna since I will have it on the roof of my vehicle with a NMO Mount with 50 ohm Match. Vswr < 2.5:1 if possible. Is there such a mobile scanner antenna? Anyone have any good ideas with name brand or model number? Need a good long lasting mobile scanner antenna!
Old 12-10-2013, 1:34 PM
popnokick's Avatar
Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 7_0_4 like Mac OS X) AppleWebKit/537.51.1 (KHTML, like Gecko) Version/7.0 Mobile/11B554a Safari/9537.53)
Diamond D-220 gets you close on VHF-HI with 2.15 dBd gain, but you'll be hard pressed to find something hitting 3db or better on a wideband mobile antenna that you'd want on the vehicle rooftop.
Old 12-10-2013, 9:47 PM
signal500's Avatar
I have had good luck with the Austin 500C31 on coverage for the bands you described, but finding one that will give you 3dBi on all bands will be a challenge.
Austin Antenna Triune Series Multi-band Antenna Information Page
Another good antenna is the Laird Technologies multi-band antenna that gives unity on VHF and 6 dBi on UHF/700/800 MHz
Laird Technologies WPD136M6C-001 136-174/380-520/760-870 MHz Antenna w/ Spring | TESSCO
Doug - K4DPS / WPUT291
My YouTube channel: http://www.youtube.com/user/k4dps
Proud owner of Electra's Bearcat III, Uniden's Bearcat BCD536HP, BCD436HP and many models in between.
Old 12-11-2013, 4:40 PM
profiledescent's Avatar
…. I am looking for a Scanner Antenna that covers 136-174 (VHF) 380-560 (UHF) and 700/800. I do not want a scanner antenna that has "Unity dBi " I want one that has at least 3 dBi on all bands. I am also wanting a Spring Loaded Antenna since I will have it on the roof of my vehicle…. Vswr < 2.5:1 if possible…..!
You mention "Unity Dbi" and 3dbi, as well as VSWR of <2.5:1. Are you planning on transmitting?
The spring equipped antenna and on the roof are good ideas. If all you are going to do is receive, just put an 18 inch VHF quarter wave antenna up there. It will hear all of those bands just fine, and cost you a whopping $20 max.
Old 12-12-2013, 8:50 AM
kmh603's Avatar
No Plans on Transmitting. Antenna will only be used for a Scanner. Just trying to find a great all band mobile scanner antenna with good dbi?
Thanks for the replies.
Old 12-12-2013, 9:38 AM
If all you are to use the antenna for is receiving, db, dbi, and VSWR are pretty much meaningless.
I mounted my scan antenna (1/4 wave VHF) on an "L" bracket, about midway betweeen the front and back of the bed, drivers side INSIDE my truck topper. I put it there for some spacing from the three transmitting antennas already mounted on the roof. I hear 10m Ham, Air, 2m, VHF/UHF public service, 700/800, and even 1.2 gig Ham with no issues whatsoever.
edit to add note: It's a fiberglass topper.
Old 12-13-2013, 4:14 PM
For mobile scanners, I've always just used a simple VHF quarter wave 18" whip. It works great at VHF, works good as a 3/4 wave antenna at UHF, and at 800, it received enough signal that I never noticed whether or not it was sub-optimal... it just worked, and signals were similar to a 1/4 wave 800 spike.
I see dead pixels.
