suction cup antenna
ffemt613
Oak Harbor, WA
anybody have anything good and/or bad to say about suction cup mount antennas? Im communting in a car that is hard to mount anything onto, so one of these are pretty much my only option.
this is what im looking at...
In-Car Mobile Antenna with BNC
looking forward to any and all input before I make a final decision.
Thanks!
ecps92
Taxachusetts
That is one option, I've used it, but only for Hotel/Travel
My best two mobile options were the over-the-window lip with BNC's, as I could change the antenna to what my monitoring interests were.
there is/was also a suction cup version where you could use your own antennas
Thanks!
krokus
Southeastern Michigan
Any of interior antenna is a last resort type of thing. They work, but not well, in my limited experience.
Sent via Tapatalk
LIScanner101
Palm City FL
I've found that the best mobile antenna inside a car is never as good as the worst mobile antenna outside a car.
Would you consider a mag-mount on your roof? It's not actually being "mounted" per se.
NHdave
Southeast NH, USA
I used one of those at my last apartment and it was an improvement over the rubber ducky on my Pro-106. I at some point plan on getting a BCD396XT and a Uniden remote head for my car and plan on using it for that as I will absolutely not install an external antenna on my car.
MacDon
Missouri
Same boat
Im working on the exact same problem. I figured a broadband through-glass would work but i don't know how well they work. I even tried patching the scanner into the fm antenna but caused too much attenuation and lost all AM and half FM stations. Im about ready to do a mag mount myself. Any suggestions on a concealed or disguised antenna?
krokus
My on glass antenna worked fairly well. It was a bit short, but VHF still came in well.
Not wanting to hijack, but how did you patch in to the car's antenna?
Sent via Tapatalk
mark40
Pike County, Pennsylvania
I've tried 1) the in-car mobile, 2) scanner coupler, and 3) duckie suction cup mount where you couple on your own antenna. Best results were with #3 coupled to a Diamond RH77CA.
MacDon
Missouri
Concealed / Disguised Antenna
Sent via Tapatalk
I went through Amazon and found Ford to Motorola connectors, antenna splitter (motorola style) and then back to Ford from Motorola. My other option was to cut away the sheath and solder the leads in the antenna cable but then i was afraid of more signal loss. I tried using the sirus XM antenna (SMB to BNC) but had the same problems. Im thinking about running a thin coax in the front windsheild and back glass as a temporary fix until i figure out an antenna idea. Much like the suction cups but with double the exposure.
Im covering 27 MHz to 956 MHz...do you think the through glass antenna work? Height is not a problem, I have a 5' firestik antenna mounted on the bed
Soundman
N.C
A
I am using the suction cup antennas right now on two of my bases scanners thy work good. But for a car you should use a magnet antenna .You will get the best reception . Or the car radio kit .That will gave you good reception to .
kb3isq
Shippensburg, PA
I use a R/S 20-032 mag mount antenna and you can't beat it. It is app.$39.00. I have three and the last one I bought on ebay with a port cb radio for $11.00
ecps92
Taxachusetts
I've found carrying a variety of Antenna's also helps with those type of antennas.
800, 900, UHF, VHF, telescoping, dual-band, changing them out helps also when traveling and you get stuck in RF Hell.
MacDon
Missouri
Help
Thanks guys for all the input. I think im going to get a short magnet on the roof.
