bob-the-scanner-man
I'm trying to use a Radioshack Pro-96 in my car and having terrible results. With the 800mhz rubber ducky I have a lot of dead areas and garbled traffic.
I figured that mounting an antenna on the car would make a difference but I'm still not having much luck. Right now I'm trying this antenna which advertises 2db of gain. Reception is much better but still not great. There are lots of areas where I should be receiving the control channels clearly but they still break up. Earlier I was about 3 miles from one of the tower sites and was still receiving garbled traffic and the control channel was cutting in and out.
So should I try some other kind of antenna instead or is there something else going on here? This is a simulcast system.
The scanner works great when I'm in my house, but I'd like to be able to take it with me when I'm in the car.
