Antenna interferance
robertson40
Member / Delaware Breaking News DE110
Dover Delaware
I am wondering if antennas will interfere with each other if stacked on a single pole, if so what clearance between antennas should be maintained.
I'll be using 800mhz and VHF / UHF
Sent from my SM-G900P using Tapatalk
I should add that if you are running a bunch of different receivers you can get some noise from the local oscillators in the different radios if the radios are too close, or if the radio has poor filtering, poor coax, etc.
robertson40
Dover Delaware
What's the best and cheapest coax cable for outdoor use ?
