Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas - For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
Old 07-16-2017, 10:07 PM
Default What kind of antenna is this?
Sent from my SM-G900W8 using Tapatalk
Old 07-16-2017, 10:19 PM
That is most likely an aspirated shield for a temperature sensor, or some other type of sensor. They can be passively aspirated, or fan aspirated (solar powered sometimes):
https://www.thingiverse.com/thing:1386003
https://www.campbellsci.com/solar-radiation-shields
Old 07-17-2017, 6:38 AM
krokus's Avatar
Agreed. Part of an ASOS or AWOS.
Sent via Tapatalk
Old 07-17-2017, 10:57 AM
n3ouc's Avatar
That is not an antenna at all. This is a shield for temperature and humidity sensors on a weather station set up.
Mike Stanton (N3OUC)
Old 07-17-2017, 12:59 PM
I do agree that it is a weather station. However, Verizon installed an antenna that looked similar to this at my grandmas house to get better cell signal and it looks similar to this.
Encryption Kills Interoperability
Radio Shack Pro-94 / Pro-197 / Pro-651, Uniden BCD996XT, ICOM A-214, Baofeng UV-5R V2+ (3) / UV-82, Kenwood TK-880, Motorola HT-750 / CT250, TYT TH-7800
Old 07-17-2017, 1:58 PM
I agree with all the replies regarding weather instrument shielding; HOWEVER, I'd love to see this antenna that DRAYD48 referred to and learn more about it.
Old 07-17-2017, 2:02 PM
Can you get and post a picture of that antenna?
Old 07-17-2017, 2:47 PM
I suspect he was referring to: https://www.verizonwireless.com/home...net-installed/
which is not available anymore, I think. He did not mention WHEN this was installed at his Grandmother's home.
Old 07-17-2017, 3:33 PM
In my last post the URL got truncated for some reason?
It should be: https://www.verizonwireless.com/home...net-installed/
Old 07-17-2017, 3:37 PM
It did it again!
missing part should be/home-services/lte-internet-installed
I give up.
Old 07-17-2017, 3:47 PM
Originally Posted by ab5r View Post
It did it again!
I give up.
Cut and paste this link:
HTML Code:
https://www.verizonwireless.com/home-services/lte-internet-installed
Old 07-18-2017, 1:31 PM
Thanks guy that makes sense. This was part of a dragging equipment detector for CN rail.
